sennheiser headset D10 USB in RDP
Discussion in 'Windows' started by ags, Dec 23, 2017.
  1. ags
    ags
    Jan 8, 2013
    9
    hi,
    i have this system environment:
    server Windows server 2012 for access in desktop remote from thinclient HP 510t
    3cx 15.5
    the device seenheiser headset D10 USB is connect to thinclient
    if use the headset for to listen from media player is ok
    if use the headset for to register ( speak ) with sound recorder is ok
    first problem with 3cx is to speak from microphone of the headset: the audio produced is incomprehensible.
    while the listening audio is ok.
    second, hi have installed the software sennheiser ( driver & plugin for 3cx )
    unfortunately I can not see in 3cx winphone the sennheiser device.
    obviously on a PC everything functionality works perfectly: audio and command from headset ( answer, volume, mute )
    help help
    thanks
    Giulio
    #1 ags, Dec 23, 2017
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @ags
    If i understand correctly the client is installed on the server which you access from the thin client and the sennheiser device is installed on the thin client. For RDS/thin client environment the 3CX client should be used in CTI mode exclusively (paired with a hardphone). In softphone mode the audio would pass through remote playback/recording devices, which may cause audio issues/latencies, and is thus not supported.
    Note also that for CTI to work correctly, PBX, softphone, and hardphone must be on the same LAN.
  3. ags
    ags
    Jan 8, 2013
    9
    Thank you for your answer.
    for your information I tried to use Sound Recorder of windows the registration from microphone is perfect.
    because ?
    I would have liked to be able to delete the hard phone ....
    Giulio
