Then I am very lucky. I am using a (low speed) fax machine, a SPA3102, a VoIP provider that does not support t.38 and I can make successful fax transmissions.leejor said:Fax over VoIP can be very hit or miss.
MasterX said:my line fax is attach with line2 of my patton
can i send fax using the patton?
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
