Separate call by name directories
Discussion in 'Ideas' started by Yury Rabinovich, Apr 20, 2017.
Separate call by name directories 5 5 1votes
5/5, 1 vote
  1. Yury Rabinovich
    Apr 13, 2017
    10
    Hi, This has been brought up in different threads but I don't see it listed as an idea. It would be very useful to have the ability to have the call by name feature broken up by the groups.
    Example: Customer has three small offices, all running off of one hosted PBX.
    Extensions are grouped per location, NY, NJ, Miami.
    Each extension group should have it's own call by name directory that can be assigned when setting the option in the IVR settings.
    Thank You
