Separate VoiceMail Beep.wav from Page Tone beep.wav
Discussion in 'Ideas' started by the112, Jan 30, 2017.
Separate VoiceMail Beep.wav from Page Tone beep.wav 4.8 5 16votes
4.8/5, 16 votes
Tags:
  1. the112
    Jan 30, 2015
    Right now the single Beep.wav file is used for both voicemail and paging. Clients wish to disable the paging tone going across the paging system.
    Currently if you remove/rename the beep.wav it will remove the paging tone but it also removes the beep when leaving a voicemail.
    This is a VERY simple fix and slight change in resource files.
    secure11 likes this.
  2. secure11
    Sep 8, 2016
    3cx please make separate prompts or allow us the ability to enable or disable the paging beep. We use the SNOMPA1 and that device has an option to disable its own prompt so it would seem fitting that 3cx would follow suit.
  3. giwm
    giwm New Member
    Sep 27, 2016
    236
    41
  4. TC-MagazineK12
    Jul 22, 2017
    7
    7
  5. ChefPol
    Oct 4, 2017
    Or better yet, in the paging settings, have a check box that can enable or disable the broadcast of the beep. Or the option to pick what wav file can be used.
  6. Peter OKeefe
    Dec 14, 2017
    7
  7. nitrox
    Sep 10, 2016
    88
    11
  8. Fred Vierra
    Nov 20, 2017
    13
    We really need this option..
  9. eashton123
    Apr 23, 2018
    I could really use this option also. First complaint from staff when I implemented the 3cx system today.
  10. BlueBit
    Mar 25, 2014
