seperate Phonebook for Extension Groups? (3CX 12.5)
Discussion in '3CX Phone System - General' started by Futureweb, Oct 15, 2015.
  1. Futureweb
    Futureweb New Member
    Jun 29, 2015
    163
    17
    Hey there,
    is it possible to have sperated Phonebooks for Extension Groups?
    I need seperated Phonebooks for some Departments ...
    Hope you can help me on this, thx
    Andreas Schnederle-Wagner
  2. IT Hamster
    May 21, 2015
    43
    I'm curious to know this answer as well. So far I'll i've managed to do is hide a given extension group from the phonebook or block access to it, but not create discrete phonebooks.
    There may be a way to do it through the provisioning template- change the path that gets used for the .xml file that is the phonebook- but that would be a lot of manual work and wouldn't update readily or respond to user input.
  3. PhatPanda
    Aug 26, 2015
    58
    Also interested, but more for two separate companies under the same ownership, on the same server.
  4. wtrbhe
    Oct 9, 2015
    22
    Same Problem here, need different phonebooks for different extension groups.
    We are on V14 Sp1.
  5. Futureweb
    Jun 29, 2015
    163
    17
    I opened a feature request - please "Vote it up" and comment ...
    http://www.3cx.com/forums/multiple-phonebooks-43231.html
    Andreas
  6. Frank D
    Frank D New Member
    Oct 6, 2014
    215
    6
    I think another more general feature might solve this:
    Editing groups on bulk (multi select and edit). As fas as I know this is not possible at the moment. Of course you can manually go to the extension list an pick each extension (with STRG + Select), but if you have lots of phones, it is not really a practical approach. There is no way to filter or sort for groups and have a multi-select edit, or is their?
    This way you could add a BLF Key with a shortcut to a special phonebook, or a choose an adapted provisioning template just for this phone.
    Is there maybe already a way to include the group as a parameter in the provisioning template and than use it to trigger IF statements?
    If not, this would be a really great an mighty feature. You could add lots of code, which is specific for some groups.
    Perhaps someone can comment, if those feature already are available and I just missed them. Otherwise I will add a feature request each.
    Best regards Frank
