Seperate user rights PBX
Discussion in 'Ideas' started by jeroendebruijn, Mar 30, 2016.
Seperate user rights PBX 5 5 1votes
5/5, 1 vote
  1. jeroendebruijn
    Nov 9, 2015
    35
    17
    Features I Like to see, or atleast what my clients are demanding
    • 1) 2Factor authentication for website login. More and more an ISO requirement. It one of the few things that I am missing
    • 2) Download Conversation Recordings from web interface
      • a. It is possible, I know, but then I have to give them too many administrator rights, and I only want them to give the option to download either their own recordings, or all recordings
      • b. Yea, it is possible with the cti Client, but then again, many are not willing to use it. That is why hardware phones are still big.
      • c. Email is neither an option: email usually sits in the cloud, and playing sound form our cloud is a NO
      • d. A simple login into the website with their own number and password and a section recordings with their own recordings seems no more than a reasonable request.
    • 3) Address book editing form the pbx website
      Much alike Call recording, it should be a separate option that can be turned of or on for users, without them getting additional rights
    • 4) Enable or disable tabs for each user extension E.g. turn the abilty for the usere to edit the separated tabs of their extension on and off.
      • a. Usually a sure will not need anything more then the option General and voicemail
      • b. General to change the call forwarding (mobile phone number)
      • c. Voicemail to change voicemail easier then trough the voicemail menus’s
    [/list]
  2. George FBS
    Apr 18, 2016
    I would love this feature. A lot of clients have asked how to access call recordings and whilst some are happy to use the 3CX Client; a lot of them aren't. It also doesn't give managers and directors any way to listen to recordings from other extensions through their phone.
  3. Tertius
    Feb 24, 2016
    43
    I know it's been a while since this post but I thought I'd respond as there was little feedback.
    I created an web interface that allows, selected user, the ability to listen to or download. I made use of both APIs supplied by 3CX to get this right.
    If this is still a requirement for you then give me a shout.
    Mitchel
