Server 2012 Device CALS
Discussion in '3CX Phone System - General' started by 3CXNewbie, Feb 24, 2014.
  1. 3CXNewbie
    Jul 18, 2013
    22
    Hi there,
    Can't find this listed anywhere on the forum. Apologies if this has been discussed before.
    We will be building a system with 75 Yealink handsets on a dedicated server running Microsoft Server 2012. The server will only be for the 3CX system and DHCP will be performed on a separate server running LINUX.
    Does Microsoft Server 2012 class IP handsets as Network devices and require device cals for these? I believe not as the devices are not using any of the Microsoft Server tools. :?:
    Thanks.
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    NO Cal required at all for the phones.
