Server 2012
Discussion in '3CX Phone System - General' started by csp, Sep 16, 2015.
  1. csp
    csp
    Apr 24, 2015
    14
    Hello every one ,
    I'm having an issue and i would like if anyone knows how to resolve it.
    Well i have a server 2012 R2 with 2 Ethernet cards. I installed the 3cx system .
    So in the first adapter i connect my internet provider and in the second adapter the VoIP provider.
    I want each adapter to have a specific DNS address . Because now the VoIP goes through the DNS of the internet and the VoIP service cant register because is looking its own DNS address.
    By the way in the adapters settings both cards have different dns address and gateways. Also i have done static routes to set my default gateway is.
    So who to tell each card where to look for its DNS ?
    Thank you
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
    Not sure if this is a support network setup for 3CX, I know two network cards is not.
    I would put a router which can handle two wan connections and using routing point the traffic down the correct ISP link
