"Server Activity Log" - historic log files where are they
Discussion in '3CX Phone System - General' started by zoomzoomvince, Apr 11, 2011.
  1. zoomzoomvince
    Jul 31, 2008
    19
    The "Server Activity Log" in the console is very usefull for seeing what is currnetly happening but because I have the logging level set to 'Medium' it tends to wrap around very quickly. I have also got a tick in the "keep backup of log files". The question is where are these log files because I need to examine a possible hack attempt from last week.
    Regards
    Vincent
  2. zoomzoomvince
    Jul 31, 2008
    19
    Re: "Server Activity Log" - historic log files where are the
    Well, there's nothing better than being able to answer your own question. The 'Server Activity Log' files are not stored under "C:\Program Files\3CX PhoneSystem". They are under "C:\Documents and Settings\All Users\Application Data\3CX\Data\Logs"
    You will find a seperate directory for each date.
