- Joined
- Apr 20, 2016
- Messages
- 120
- Reaction score
- 35
I'm not trying to reinvent the wheel so I figured I would ask... Is there a certain antivirus you use on the server that you have had good luck with (i.e. not breaking the 3CX)? I did see that we need to make sure a couple folders are excluded but that is all I see.
Antivirus Software should not scan the following directories to avoid complications and write access delays:
C:\Program Files\3CX PhoneSystem\*
C:\ProgramData\3CX\*
Also found this on another blog:
Here are the ones that we have noticed do not cause an issue with 3CX.
-Trend Micro (Be sure that the 3CX folders are in the exclusion list)
-Microsoft Security Essentials
-AVG
Thank you in advance
-AVG
