Server Shutting Down?? WHY?
Discussion in 'Windows' started by thereverend, Jun 18, 2011.
  1. thereverend
    thereverend New Member
    May 29, 2011
    100
    This morning i noticed that i was not getting calls. I went to log onto the interface via HTTP
    and could not get there.. So i REMOTED into the server and after about 30 seconds from doing that the phones worked again
    is there something that keeps shutting the server down when i log out from the remote desktop connection?
    is there a setting to keep the server alive even after i log off?
  2. willow
    willow Member
    Mar 1, 2011
    471
    you will want to look at power saving options or something like that. windows updates have a nasty habbit of turning power saving features back on even after you turn them off.
