Server spec
Discussion in '3CX Phone System - General' started by oliverm, May 30, 2012.
  1. oliverm
    Mar 10, 2009
    79
    Hi chaps
    We are doing a quote for a 3cx server for 50 users but only 30 concurrent calls (32 licenses).
    It won't have the call centre addon but will have call recording.
    Anyone spec'd anything similar? What hardware are you using?
    From our experiences we are planning to use a quad core i5 with Windows Server on it and 16GB of ram with twin SATA drives.
    Any comments?
    Olly
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,333
    256
    64 license 60 users
    Running on a current Mac mini 8gb ram win 7 vm ware
    I think if I were to start over I might go with mirrored drive...
  3. voipvillin
    May 17, 2012
    Do you have the recording option on your system now? Are you able to retrieve calls easily or is it a hassle to find the call/s you are looking for?
  4. craigreilly
    Feb 1, 2012
    3,333
    256
    We do not record all calls if that is what you are after... People have the option to if need be.
    So they have access to their own calls in myphone.
  5. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    you can run 3CX on about any hardware and about any Windows OS... Even crapple would work, if you like to spend money for nothing..
