Server specs
Discussion in '3CX Phone System - General' started by oliverm, Mar 6, 2010.
  1. oliverm
    Mar 10, 2009
    79
    Is there a guide to server specs for a very small implementation of 3cx? We have <5 users, prob about 8 handsets around the office, maybe 50 calls a day or so.
    Olly
  2. sipero123
    Nov 24, 2008
    94
    I would suggest you use the recommended rather than minimum spec. Please feel to PM me if you want to discuss further.
    Jonathan Hamon
  3. oliverm
    Mar 10, 2009
    79
    Is there even a recommended spec? I'd be happy with any spec but I can't see one on the website
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    The system requirements can be found on the manual on page 15:
    http: //www.3cx.com/manual/3CXPhoneSystemManual8.pdf
    Also in regards to the phone you want to use you should have a look at our supported phones list:
    Code:
    http://www.3cx.com/support/
  5. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    That size deployment would be fine with an Atom 1.2ghz system with 1gb of RAM.
  6. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    306
    Hi Olly,
    For that install you can use a non dedicated machine and install it on an existing server if you have one available...
