Service Pack Rollback
Discussion in '3CX Phone System - General' started by stash, Jan 11, 2013.
  1. stash
    stash New Member
    Feb 23, 2012
    213
    Can i roll back to previous Service Pack? Does Service Pack includes on firmware backup?
    Thanks,
    STASH
  2. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    Hi Stash
    You would have to load a previous version of 3CX without the service pack, and restore your 3CX from a pre-upgrade back-up. What version of 3CX are you wanting to roll-back to?
    best regards
  3. stash
    stash New Member
    Feb 23, 2012
    213
    Hi Fox,
    I have one client who is asking me if they update the 3CX v11 SP1 to SP3 can they roll back to SP1 in case they experience problem on SP3. I'm also curious if this is possible.
    Thanks,
    STASH
  4. 3CXfoxhallsolutions
    Sep 8, 2012
    211
    You can do it - but - you need to have kept the earlier 3CX software, as the link to the software download on the 3CX website is always the same link, but will always give you the most recent version to download i.e. unless you archive the software yourself, it's not easy to get earlier versions.
    You may also have problems regarding the backup file ... It seems OK to upgrade 3CX then load a back-up, but I don't know how it would work if you downgraded 3CX then restored what would be a back-up created under a later 3CX version. To be sure - you would need to restore your configuration from an earlier back-up which was made under the 3CX version that you are downgrading to ...
    I've had to do this once when I found that the back-up I had taken prior to an upgrade, was corrupt. It worked - but fortunately, I wasn't having to go back in history too far - and therefore, was not loosing any recent configuration changes ...
  5. stash
    stash New Member
    Feb 23, 2012
    213
    Hi Fox,
    OK will take note.
    Thanks,
    STASH
