Service Pack
Discussion in '3CX Phone System - General' started by tobiastromm, Aug 29, 2012.
  1. tobiastromm
    tobiastromm New Member
    Jun 26, 2010
    138
    Just curiosity.
    There is a prevision for a new service pack for v 11?
    Thank You.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    What are you trying to ask?
    The current version of 3cx within the Management Console is v11.0.26364.600.
    It reports as SP1 in the Update menu.
  3. tobiastromm
    Jun 26, 2010
    138
    I'm trying to ask about SP 2 : )
    Thank You.
  4. craigreilly
    Feb 1, 2012
    3,575
    305
    How about SP1 first ?
  5. tobiastromm
    Jun 26, 2010
    138
    Ok, how about it?
  6. leejor
    11,116
    329
    If there has been a service pack released, applicable to your version, the appropriate menu will show as red in the left column. 3CX checks to see if there is an update and will make that fact known. You just have to check the menu.
