Session Border Controller Installation Failed
Discussion in '3CX Phone System - General' started by efthimis, Aug 25, 2014.
  1. efthimis
    Jun 13, 2014
    40
    I tried to install the 3CX SBC (http://downloads.3cx.com/downloads/3CXSBC12.msi) but the installation failed because it cannot start a service. I tried to install it on Windows Server 2008R2, 2012 and on Windows 8 but without any luck. In all cases i tried to installed it as Administrator. Can someone send me the correct exe file? Thanks!
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,386
    88
    Hi!
    I also had this issue and apparently it was caused by downloading a peculiar version of the installer. The way I fixed it was:
    - Delete the file you have stored on you machine.
    - Clear the browser history (or use private browsing mode).
    - Input the link to the file you already have (http://downloads.3cx.com/downloads/3CXSBC12.msi) and re-download the file
    - The correct file size you should get is ~1.9MB and not ~2.2MB.
    - If you are still getting the wrong file download and use a different browser.
    This worked for me.
