Set 3CX soft phone status to DND when Windows account is locked
Discussion in 'Ideas' started by jmusu, Mar 15, 2017.
Set 3CX soft phone status to DND when Windows account is locked 5 5 15votes
5/5, 15 votes
  1. jmusu
    Mar 15, 2017
    Is it possible to set the status of the 3CX soft phone to automatically change to DND when locking the Windows account (Ctrl+Alt+Del -> Lock)? This would be useful for example in cases when users only use the soft phone on their laptop/computer (with no physical phone) and they lock the computer before leaving their desk (for example when on break). This will avoid the phone ringing and disturbing other people in the same room.
    jbryant84 likes this.
  2. Truman King
    Mar 15, 2017
    I second this idea. Windows Key + L also locks the PC; we need to do this often at work because of the secure data that we use. Having the softphone set to DND automatically (or even being able to pre-define a status for PC locked) would be very helpful.
  3. tomnorton
    Feb 23, 2015
    21
    I also vote for this feature request.
  4. Lev
    Lev New Member
    Sep 19, 2015
    127
    20
    If you would do this only, all other registered clients would not ring anymore.
    So it should be an option only, not standard.
  5. Tobias Pieper
    Dec 31, 2017
    6
    Yes! :) I vote for this Feature.
    btw: this feature stay on skype or skype for business for more then ten years.
  6. Tony Cave
    Jun 8, 2017
    30
    Bump, We have customers migrating from Mitel Asking for this feature as well
  7. Matt Ryan
    Sep 15, 2018
    18
