Set DTMF Type setting using Yealink Template
Discussion in '3CX Phone System - General' started by jhicken, Jun 15, 2011.
  1. jhicken
    May 21, 2010
    25
    I am trying to figure out how to hard set the DTMF Type to INBAND using the Yealink Phone Template.
    The template currently has these settings for DTMF:
    [ DTMF ]
    path = /config/voip/sipAccount0.cfg
    DTMFInbandTransfer = 1
    InfoType = 0
    DTMFPayload = 101
    A new T28P model with this setting has the Type set to RFC2833
    I can manually change it from RFC2833 (which doesn't work very well working with a lot of systems that requires tones to work properly such as Call Conferencing systems) but I don't want to do that on 160 phones.
    Any ideas on what I need to change in the template?
    Thanks!
  2. willow
    willow Member
    Mar 1, 2011
    471
    when I did an export of DTMf set to RFC I get this:
    [ DTMF ]
    DTMFPayload = 101
    DTMFToneLen = 300
    InbandDtmfVolume = 0
    RxLatency = 20
    CPTToneCountry = 12
    G726CodeWord = 1
    InfoType = 0
    InfoTypeOEM = 0
    When I did an export of DTMF set to Inband I get this
    [ DTMF ]
    DTMFInbandTransfer = 0
    DTMFPayload = 101
    DTMFToneLen = 300
    RxLatency = 20
    CPTToneCountry = 12
    G726CodeWord = 1
    InfoType = 0
    InfoTypeOEM = 0
    so it appears that inband is 0, RFC=2833 is 1 and sip info is 2.
  3. willow
    willow Member
    Mar 1, 2011
    471
    [ DTMF ]
    DTMFPayload = 101
    DTMFToneLen = 300
    RxLatency = 20
    CPTToneCountry = 12
    G726CodeWord = 1
    InfoType = 0
    InfoTypeOEM = 0
    [ DTMF ]
    DTMFPayload = 101
    DTMFToneLen = 300
    RxLatency = 20
    CPTToneCountry = 12
    G726CodeWord = 1
    InfoType = 0
    InfoTypeOEM = 0
  4. jhicken
    May 21, 2010
    25
    Awesome!
    That should be exactly what I need!
    Thanks man!
    :D
