set Supervisors phone to ring on Receptionists phone
Discussion in '3CX Phone System - General' started by imabev, Aug 17, 2012.
  1. imabev
    Aug 17, 2012
    56
    I haven't figured out any good way to do this yet. For example, we have a "supervisor" and a "receptionist". The supervisor doesnt answers calls directly so if it rings on his extension it must ring on the receptionists extension so that she may answer it and transfer it in to the supervisor. How can I set this up?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    What kind of phone does each have? This may determine some of the options.
  3. leejor
    11,083
    325
    If she has a multi line set, you can program one key as the supervisors extension number. When his line rings, so will hers (hopefully at a different cadence or lower level so as to distinguish calls). He could even have a second extension appearance on his set, one that only the receptionist will call (transfer calls to). Heck, if he never answers his own calls, why even have his regular extension number even appear on his set, just put it on the receptionists set and she can screen all his calls the transfer them to his "other" extension number, the one known only to her.
  4. imabev
    Aug 17, 2012
    56
    We have Yealink T28.
    The first step I need to understand is where do I put the supervisors extension number? Do I program the supervisors extension in one of the 6 "line" keys (in the LCD readout)? What do I set the button as - theres many different options in the line type drop down. I tried to add a second account on the receptionists phone and it just caused problems.
  5. leejor
    11,083
    325
    Not having used the Yealink, I can't help on the programming details. Being a multi line set should allow for the appearance of the supervisors extension number on a key, and possibly the busy status of his set. Someone more familiar with that model might be able to help.
  6. imabev
    Aug 17, 2012
    56
    I got this mostly figured out. I just needed to create another account on the Yealink and it rings on both phones as expected. The only thing I would like to eliminate is the supervisors voice mail notice on the receptionists phone. She doesn't need to know he has voice mail and will only add to confusion.
  7. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,551
    298
    Check the Account / Advanced settings for the "Subscribe MWI". I haven't played with it but would expect this to be what works. On the receptionist phone turn this off for the Supervisor phone.
