Set timeout for disconnected calls that lock up extensions
Discussion in 'Ideas' started by mdc2, Dec 29, 2015.
  1. mdc2
    Jul 15, 2009
    7
    Set a timeout to disconnect a call after a period of time for the Page Extension or for any other call that may get stuck in the system due to the caller disconnecting form the network so that you don't have to enter the Management Console to terminate the call from the System Status -> Extensions View option or by having to restart the 3CX Services from the Windows Server the 3CX Phone System is installed on.
    This would allow for the system to automatically clear locked up connections and save a lot of management if you have these kinds of disconnects.
  2. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    There is "MAXCALLDURATION" - This is the maximum timeout for connected calls Default is 3 hours. Calls will drop after this time.
    http://www.3cx.com/blog/docs/calls-end-after-3-hours/
    I haven't tried using SIPPINGPERIOD
