Set up 2 digits DID
Discussion in '3CX Phone System - General' started by Giorgio Ruga, Mar 16, 2017.
  1. Giorgio Ruga
    Dec 19, 2016
    On a 4 channel isdn line with a patton gateway the trunk provider give us only 2 digits.
    How can we handle this with 3cx ?
  2. Drew9213
    Sep 16, 2015
    62
    I would call your provider and have them change to sending you at least the last 4 digits, but I personally prefer the last 7 digits. You could make two digits work I guess by making your DID something like *12*, but I would definitely recommend trying to get that changed to 4 or 7 digits from your provider.
