Setting Backup breaks Management Console
Discussion in '3CX Phone System - General' started by Shon, Jun 29, 2017.
  1. Shon
    Jun 29, 2017
    I recently setup a backup routine, and have it going to my Google Drive. It seems this has broken something, as every time I try to load my servers management console I get a 502 gateway error. I can then ssh in and start the service, and everything stays fine until I try to go in to the Back/Restore area of the management console. That crashes the MC service, and I again have to manually start it.
    The System Server service is also in a stopped state always. Even if I try to manually start it, it will start then crash.
    This all happened after I setup the backup, is there a way I can ssh in and edit/delete the backup set?
    I am running on Debian 8 64bit, with v15.5 of the 3CX server.
    #1 Shon, Jun 29, 2017
