Setting Holidays
Discussion in '3CX Phone System - General' started by AlexDBarrett, Feb 12, 2015.
  1. AlexDBarrett
    Jan 25, 2011
    71
    9
    I am using a Cloud Server.
    Are the Holidays in Settings/General/Configure Holidays stored in an xml file which I can copy and paste across tenants saving time in configuring tenant by tenant?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Unfortunately no there is no such xml or import/export of holidays. Kindly post this as a feature request on 3cx Ideas : http://www.3cx.com/ideas
  3. AlexDBarrett
    Jan 25, 2011
    71
    9
    Posted as suggested.
