Setting inbound rule
Discussion in '3CX Phone System - General' started by tomaz, Mar 2, 2008.
  1. tomaz
    Feb 27, 2008
    12
    I have got block of numbers from ITSP. It starts from 11 11 510 to 11 11 519. I have 5 VOIP channels.
    Setting up the first line (1111510) was easy. Here is a log of successful inbound call:
    02:04:14.453 Call::Terminate [CM503008]: Call(30): Call is terminated
    02:04:14.437 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:<secret> forwards to DN:300
    02:04:05.093 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(30): Calling: RingAll:300@[Dev:sip:200@192.168.2.21:5060]
    02:04:05.078 Line::printEndpointInfo [CM505003]: Provider:[DetelProvider] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhoneSystem 5.0.3790.0] Transport: [sip:192.168.2.5:5060]
    02:04:05.078 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:<secret> forwards to DN:300
    02:04:05.046 CallCtrl::eek:nIncomingCall [CM503001]: Call(30): Incoming call from 0444444@(Ln.<secret>@DetelProvider) to [sip:300@192.168.2.6:5060]
    02:04:04.796 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:<secret> forwards to DN:300
    On the other side, setting up inbound rule for second external number (1111512) is a bit of the problem.
    Here is a log of unsuccessful inbound call.
    02:03:56.890 evt::CheckIfAuthIsRequired::not_handled [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:1111512@123.123.123.123:5060;user=phone SIP/2.0
    Via: SIP/2.0/UDP 80.246.224.111:5060;rport=5060;branch=z9hG4bK4452a28fa4e271639a2a75e95fa44d10
    Max-Forwards: 70
    Contact: [sip:80.246.224.111:5060]
    To: "1111512"[sip:1111512@123.123.123.123:5060]
    From: "0444444"[sip:0444444@80.246.224.111:5060;user=phone];tag=GR52RWG346-34
    Call-ID: 203382008-83FCF35146940203170@80.246.224.111
    CSeq: 1 INVITE
    Allow: ACK, NOTIFY, OPTIONS, REFER, INFO, BYE, CANCEL, INVITE
    Content-Length: 0
    Remote-Party-ID: "0444444" [sip:0444444@80.246.224.111:5060];party=calling;screen=yes;privacy=off
    02:03:56.890 evt::CheckIfAuthIsRequired::not_handled [CM302001]: Authorization system can not identify source of: SipReq: INVITE 1111512@123.123.123.123:5060 tid=4452a28fa4e271639a2a75e95fa44d10 cseq=INVITE contact=80.246.224.111:5060 / 1 from(wire)
    where:
    80.246.224.111 is external IP of my ITSP
    123.123.123.123 is my external IP
    192.168.2.xx is my internal IP schema
    1111512 is my public tel number
    0444444 is public telephone number used to test connection (completely independent to 3CX PBX)
    <secret> is my ID towards ITSP
    I can not simply register second line, because 3CX refuses creation of another VOIP account with the same ID.
    Any ideas how to solve the problem?
  2. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    tha'ts right, there are some problems with same ID accounts. But tell me, what version of 3CX are you running?
  3. tomaz
    Feb 27, 2008
    12
    Version?
  4. tomaz
    Feb 27, 2008
    12
    This will be more suggestion to 3CX developers:
    I want to set up VoIP PBX to add VOIP lines in addition to existing Euro ISDN lines.
    Before 3CX, I have installed Trixbox, but it was unreliable (incoming calls were lost). However Trixbox has split account registration and incoming rules.
    Account registration and incoming rules are mixed together in 3CX and this is a source of the problems. 3CX says "choose supported telephony provider", but it is radically wrong approach. There are several hundreds ITSP provider in EU alone. 3CX can not make template for all of them.
    In my case, It is obvious that ITSP is aware of my presence, not only with line 11 11 510, but with all lines. This can be concludes because they send me INVITE command for number 11 11 512@123.123.123.123:5060, but PBX is unable to handle it.
    I have tried with:
    * VOIP Trunk (instead to VOIP Trovider)
    * DID/DDI account.
    Both unsuccessful.
    Any successful examples?
  5. landfiets
    Jul 17, 2007
    243
    I think also it should work with unsupported provider. Please take a look at the settings for a supported provider and try to "translate" that to yours. Maybe that will help.
  6. tomaz
    Feb 27, 2008
    12
    Dear Edwin,
    Good idea, but no result.
    Tried with:
    - 1und1
    - SipGate
    - broadvoice
    All tested supported providers have the same main settings:
    Source identification: all blank
    Gateway / Provider Inbound Parameters: always the same settings
    Gateway / Outbound Inbound Parameters: always the same settings
  7. tomaz
    Feb 27, 2008
    12
    The idea was:
    1.) be very consistent with Source Identification (enter some criteria into fields - for example: From Host part <-> GWHostPort)
    2.) create DID line 1111512 based on previously identificated trunk.
    Result?
    If anything is in the Source Identification field, PBX stops responding to all inbound calls!!!
    Please comment from 3CX.
    Thomas
  8. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Am I missing something or is it DID that you want?
    Stephen
  9. tomaz
    Feb 27, 2008
    12
    With one single registration to ITSP I get following:
    * 5 voice channels,
    * 10 external (public) numbers.
    5 vioce channels allows 5 simultaneous calls regardless of public telephone numbers. My public telephony numbers block strats from 1111510 to 1111519.
    Teoretically I can have 3 simultanoous calls on 1111510 plus 1 call on 1111511 plus one call on 1111519. Of course I can have all possible combinations that result in 5 voice channels.
    With my existing knowledge I can setup only external number 1111510. All other numbers (1111511 to 1111519) are the challenge that I am not able to handle.
    Back to your question: My Idea was that block of numbers from 1111511 to 1111519 can be only configured as DID numbers. But again: my knowledge is too weak although I spent many hours on 3CX manual.
  10. tomaz
    Feb 27, 2008
    12
    Problem solved (at list I believe so)!
    Solution is:
    * properly configured "Source Identification"
    together with
    * properly configured "DID line"
    Oddly, but
    if "Source Identification" is set to "From: Host part" <-> "GWHostPort" (set to 80.246.224.111) then DOES NOT WORK
    while
    if "Source Identification" is set to "From: Host part" <-> "Custom field" <-> 80.246.224.111 then DOES WORK
    Another odd thing:
    if "DID/DDI number" -> "Source" is set to "Anywhere" then DDI line DOES NOT WORK
    while
    if "DID/DDI number" -> "Source" is set to [my ITSP] then DDI line DOES WORK
    This should be really better documented!!! :evil: :evil:
