setting linksys WIP330
Discussion in '3CX Phone System - General' started by rico06, Jul 29, 2008.
  1. rico06
    rico06 New Member
    Jan 11, 2008
    143
    I am looking for the setting of a linksys WIP 330 outside my lan, the setting asked is the following:
    SIP Proxy:
    SIP Proxy Port:
    Registrar Address:
    Registrar Port:
    Expiry Time(sec.):
    Session Timer:
    Display Name:
    SIP Format: Normal Drop Port Drop 5060 Port
    STUN Proxy Setup
    STUN : Disable Enable
    STUN Address:
    STUN Port:
    Outbound Proxy Setup
    Outbound Proxy:
    Outbound Proxy Port:
    Authtication
    Registrar Name:
    Password:
  2. Anonymous
    Anonymous Guest
    SIP Proxy: IP of PBX
    SIP Proxy Port: 5060
    Registrar Address: IP of PBX
    Registrar Port: 5060
    Expiry Time(sec.): 180
    Session Timer: 60
    Display Name: WHATEVER
    SIP Format: Normal
    STUN Proxy Setup
    STUN : Enable
    STUN Address: stun.3cx.com
    STUN Port: 3478
    Outbound Proxy: empty
    Outbound Proxy Port: empty
    Authtication
    Registrar Name: extension number
    Password: extension pass
  3. rico06
    rico06 New Member
    Jan 11, 2008
    143
    thank you for this information
    I can receive a call with no problem with audio both way but if I make a call from the linksys WIP330 I have no audio receive.
  4. Anonymous
    Anonymous Guest
    Outbound Proxy: IP of PBX
    Outbound Proxy Port: 5060
    Can you try this setting and revert?
    Thanks,
  5. rico06
    rico06 New Member
    Jan 11, 2008
    143
    it is the same with the proxy setting but I'm not able to receive call from .
  6. Anonymous
    Anonymous Guest
    Does anyone have experience with these devices who may help here?
    Thanks,
  7. rico06
    rico06 New Member
    Jan 11, 2008
    143
    back from holidays...
    I come back to get some help from you...
    Please help me
  8. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Please tell me about your network,firewall,firmware and 3cx specs
  9. rico06
    rico06 New Member
    Jan 11, 2008
    143
    Tell me exactly what you want to know ...
    No port forwarding set at home where the linksys is use but with the port 3478 / 5060 / 9000to9015 forwarded it was the same.
    In my office all the port are open for outgoing...
    The thing very strange is that I was able to make One call working both way with no reason !!!
  10. amygoda
    amygoda Member
    Sep 18, 2006
    436
    audio in one way is nat or firewall issue
    may be you have to change your stun server or reset to factory set and reconfig
  11. rico06
    rico06 New Member
    Jan 11, 2008
    143
    I use the 3cx stun, what do I have to change ?
  12. amygoda
    amygoda Member
    Sep 18, 2006
    436
    a lot of stun servers
    sipphone
    fwd
    http://www.3cx.com/forums/stun-server-instalation-4738.html
