setting regular re register to VOIP provider
Discussion in '3CX Phone System - General' started by KaiS, Jul 6, 2009.
  1. KaiS
    Apr 1, 2009
    8
    Hi all,
    where can I set the time intervall after which a re-register of the VOIP provider will be done ?
    Kai
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,504
    100
    You need to go to your Voip Provider in the PBX:
    Voip Providers > YOUR PROVIDER > Advanced Tab > Time Between Registration Attempts in Seconds, Default is 600.
  3. KaiS
    Apr 1, 2009
    8
    well, that is what I expected, but in the server activity log I do not see the regular "sent registration request for xxx". Any other settings which enables / disables the regular update ?
    3CX is running on a Windows Server 2008 machine with direct link to the internet without NAT and without firewall, but dynamic IP.
    Regards
    Kai
