setting spa504g softkeys via provisioning template?
Discussion in '3CX Phone System - General' started by jschlatter, Mar 24, 2010.
  1. jschlatter
    Feb 9, 2010
    15
    Is it possible to change the default softkeys settings (specifically the Connected Key List) for a Cisco SPA504G via the provisioning template within 3cx? I would like to change these. I have the values needed, I just don't want to have to connect to each of my 60+ phones to set it.
  2. jschlatter
    Feb 9, 2010
    15
    just in case anyone else reads this post and is looking for the information it can be found here.
    https://www.myciscocommunity.com/docs/DOC-2148
