Setting the starting extension number
Discussion in 'Ideas' started by David Pearce, Dec 6, 2018.
Setting the starting extension number 5 5 2votes
5/5, 2 votes
  1. David Pearce
    Oct 18, 2018
    11
    Like a lot of companies, our extension numbers do not start with 0001. In our case, we start at 7300. So when I create a new extension, I have to manually look for a number available after 7300 and then enter it.
    Is there a parameter/setting to set the first extension number?
    Thanks.
  2. ghalan
    Nov 27, 2013
    17
    Yes or start after the last extension number :)
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,557
    300
