Setting Up - Dialing Out with a regular phoneline
Discussion in '3CX Phone System - General' started by sbutler, Mar 19, 2007.
  1. sbutler
    Mar 19, 2007
    8
    How can I setup my 3CX BETA 3 to use a regular phoneline? I already have a modem in the computer. How would I set that up to work?
    Thanks,
    Butler.
  2. Anonymous
    Anonymous Guest
    Modem is not good enough, you need an ATA (which can be part of a modem). This is a little device for exampla a SPA-3102 converts the "0110010010100010101" to "Hello MUM".
    So digital to analogue (assuming your regular phoneline is analogue) and back.
    You do not need a VoIP provider if you want to have all you calls going via the PSTN (POTS). You can use 3cx to dial direct to the PSTN (if you have an ata).
    I am still trying to get that back to work so I can report this back in an other discussion on this forum. I had it working but for the live of it I can not get it working again :-(.
    Henk.
  3. 3CXsupport
    3CXsupport New Member
    3CX Support
    Aug 21, 2006
    193
    I would not rule out a VoIP provider line though. They are quick and easy and require no devices hanging around. PSTN gateways have there advantages too ! If you are confused and unfamiliar with the terminology be sure to have a look at our manual for a light explanation.
  4. ocamara
    Mar 20, 2007
    For call to several countries, probably you can make the phones calls more cheaper that your analog line.
    In some cases is free!!!
