Setting up DTMFcode for Door opening
Discussion in '3CX Phone System - General' started by Parin, Oct 10, 2012.
  1. Parin
    Aug 15, 2012
    10,731
    277
    I'm not really sure what you are asking.
    I'm assuming that a call is placed by the Doorphone when someone at the door picks up a handset or presses a button. That call will ring an extension. The person at the extension will press "6" (in your case) to open the door.
    What part of that scenario doesn't work?
    Is it that the Doorphone is not responding to the DTMF? If so then you have to be sure that the DTMF Method used by the set is the same that the Doorphone is using. It may be audio, or one of several SIP messaging types. With many devices there is an "auto" setting capable of dealing with whatever is sent to it.
