Setting up Holidays
Discussion in '3CX Phone System - General' started by gehri, Jul 31, 2016.
  1. gehri
    Jan 28, 2015
    12
    Hello to all,
    tried using the new "range" feature when setting up holidays.
    I've noticed that the selected prompt won't play. Instead, when i select only the single day the prompt plays normally.
    Why?
    I think it's a bug...very annoying when setting up 30 days (30 single days....!)
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Look I suggest that first you check why when you play HOL prompt nothing is being played.
    Regarding Ranges what is annoying? Can you clarify more...
    You can set up more than 30 days and the only restriction there is if you configure ranges within different years, this is not allowed.
  3. gehri
    Jan 28, 2015
    12
    the problem is:
    1) if i set 1 single day the prompt plays (the prompt that belongs to the single day holiday)
    2) if i set a range of days the prompt won't play
    this indipendently by the HOL prompt.
    The HOL prompt contains an empty wav because is already on the "Configure Holiday" GUI.
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    We cannot replicate this, we need logs of IVR in verbose. Send me a pm and we will see what is your real problem.
  5. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    Also make sure you are on V15 SP1.
