Setting up Remote Voicemail
Discussion in '3CX Phone System - General' started by Kenny Nawotniak, Jun 26, 2017.
  1. Kenny Nawotniak
    Jun 26, 2017
    We have users that need to regularly change greetings for certain voicemail boxes. However, these voicemail boxes are not tied to the extension of the person needing to change the greeting. What is the best way for a user to dial into a mailbox that belongs to another mailbox?
  2. accentlogic
    accentlogic New Member
    Nov 14, 2013
    181
    77
    From a digital receptionist you can dial the voicemail extension number, or have the receptionist transfer you to the voicemail extension. Substitute "999" below with your PBX voicemail extension number. Enter the mailbox PIN when prompted.
    Accessing Voicemail
    From your extension: Dial 999 or press Message
    From any extension: Dial 999, Press #, enter [EXT]
    From an Outside Line: Dial 999, Enter [EXT], Press #
    teldata1 likes this.
