Setting up Time Warner Cable as VOIP Provider
Discussion in '3CX Phone System - General' started by petewatterschats, Mar 1, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    Has any one used Time Warner Cable as a VOIP Provider
    I have a Dynamic Public IP Address
    The phone service and Internet are in the same Arris TG1672
    I need advice on how to setup the SIP Trunk for Time Warner
    In the setup I assume that the SIP Server IP Address would be the Priviate Side of the TG1672 router - is this correct
    VOIP Provider Wizard
    Account Details
    External Number - where do I get this is it the phone number
    Authentication ID - where do I get this
    3 way Authenication ID - Where do I get this
  2. 12494
    12494 Member
    Apr 16, 2010
    311
    31
    I think perhaps you should be addressing this to Time Warner.
    Have you in fact purchased Time Warner SIP Trunk service? It is my understanding that they provide an edge device and a dedicated circuit for your voice with a static IP address. I've got one client with this setup but I inherited them and was not involved in the initial configuration.
    You can, however, use your TW data circuit with a third part SIP Trunk service provided you have adequate bandwidth to support both. Some SIP providers will support name/password authentication and not require a static IP address however 3CX wants you to have a static IP.
    Allen
  3. petewatterschats
    Jan 19, 2016
    151
    Time Warners people have no clue, thats why I was looking to find some who has used them.
    The static IP as a requirement by 3CX does not seem to be a little fuzzy since I have seen on the forms page some people talking about using a Dynamic IP and a Dynamic DNS service
    I would like to understand how this works and why the requirement
  4. 12494
    12494 Member
    Apr 16, 2010
    311
    31
    Try calling Time Warner ADVANCED Product Support 877-627-2892. When you reach a live person tell them you are calling about SIP trunking. You should be connected to someone that knows what you are looking for.
    Allen
