Setting Voice Name - Text to Speed
Discussion in 'CRM / Helpdesk / App Integration' started by Wilgner Garcia, Feb 17, 2014.
  1. Wilgner Garcia
    Feb 17, 2014
    I installed 2 new voices on Windows (Speech Recognition > Texto To Speech), and I wish use these voices on a Prompt in my CallFlow.
    I tried to put varous formats of name, like: 'Microsoft Heloisa', 'Heloisa', 'MIcrosoft Server Speech Texto to Speech Voice (pt-BR, Heloisa)'. And none of them worked.
    And when I let the field VoiceName empty, the voice that "is executed" is the Windows Default (Microsoft Anna), even the voice selected on control panel is another (ex: Heloisa or Hazel).
    Any other way to select eh voice?
    Thanks,
    Wilgner Garcia
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    As I mentioned in the other post, check if the voice installed is for 64 bits in case your server is x64. If you want send me your e-mail address via a private message and I will send you an application for testing which gives you the names of the voices available for x64 and x86.
    Regards.
