Settings Disappearing
Discussion in '3CX Phone System - General' started by TSlocum, Aug 26, 2016.
  1. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    16
    Last night, our DID numbers and inbound rules disappeared for seemingly no reason. A few weeks back, we also had our office hours settings disappear.
    No clue what the cause of this is, but I wanted to make 3CX aware.
  2. MultipliesStijn
    Aug 24, 2016
    7
    I have a similar issue with inbound rules, CID settings.
    Wierdly after about 30 minutes it completely forgets the CID Rules.
    I also had to reset multiple phones, multiplies times because it would show up as a new device.
    Error logs would then show something along the lines of "wrong password"
  3. travstoll
    Jul 11, 2016
    11
    Seeing this same issue with CID rules disappearing.
  4. Anonymous
    Anonymous Guest
    This has happened to us as well.
  5. AlanM
    Aug 3, 2010
    39
    I too recently had all of my inbound rules simply disappear. Fortunately, there were only two simple rules so not a problem re-configuring but a bit disconcerting from a reliability standpoint.
  6. travstoll
    Jul 11, 2016
    11
    Anyone from 3cx have a response or help to point us in the correct direction?
  7. Anonymous
    Anonymous Guest
    Honestly, I think they're working their A$$es off on the SP2 due out - I expect in October.
    Keep up the awesome work Team 3CX Devs - Really need SP2 to shine.
  8. norekhov
    3CX Support
    Jan 31, 2014
    53
    We fixed the issue which causes CID rules disappearing.
    SP2 is in final testing stage. So expect it very-very soon.
  9. travstoll
    Jul 11, 2016
    11
    Thanks @norekhov, we all appreciate the continued efforts being put into this platform.
  10. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    16
    Appreciate the update. Curious what was causing it. Did all the settings disappearing get fixed?
