setup advice
Discussion in '3CX Phone System - General' started by tazpro, Sep 23, 2008.
  1. tazpro
    Sep 23, 2008
    5
    Hi, I am new to 3cx and need some help. I purchased the following:
    6 Grandstream GXP-2000 phones
    1 Grandstream GXW 4140 (4 port analog gateway)
    I have 2 telecom providers - One provides 2 PSTN lines in port 1 and 2 of the gateway and the other provides 1 line into port 3. Port 4 is not used
    in order to get an outside line i.e. to make an external call staff should either press 9 for provider 1 followed by the number to be called or 8 for provider 2 followed by the number to be called.
    Futher to this I want to be able to have an internal extension forward to a specific phone number on provider 2 e.g. if I transfer to ext 500 it would in effect go to 8, 221-9999
    Please advise. I am not sure how to set this up and any help would be appreciated.
    Jason...
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    create ext 500
    in Destination Unreachable / Forwarding
    choose Forward All Calls tab
    in Forward to Outside Number type yours
  3. tazpro
    Sep 23, 2008
    5
    That is what I want to do - I want to be able to decide what provider to use primarily for rate savings.
  4. tazpro
    Sep 23, 2008
    5
    ok but how do i specify which line or port on the call gateway that the call should be routed through.
  5. amygoda
    amygoda Member
    Sep 18, 2006
    436
    in channels tab
    2. Prefix to Specify Port(1 stage dialing method):99
    you dial outbound rule then 99 then your channel (1:4) then your dialed number
    you can also make your dial rules prefix
    991 for line 1
    992 for line 2
    993 for line 3
    994 for line 4
  6. tazpro
    Sep 23, 2008
    5
    I am totally lost here. Where do I find the channels tab??
