Setup for Nextiva
Discussion in 'Windows' started by lhorstmyer, Nov 8, 2011.
  1. lhorstmyer
    Nov 8, 2011
    Is anyone aware of setup instructions for using this device with Nextiva? I can't quite figure out all the information asked for. Thanks for any direction.
  2. lhorstmyer
    Nov 8, 2011
    I am getting a server error....any thoughts?
  3. arad
    Jul 23, 2012
    I am also having problems setting up the PBX for Nextiva. I cannot seem to find a configuration template for Nextiva. Can anybody provide a link? Many thanks.
  4. arad
    Jul 23, 2012
    If I understand correctly, I am to use a Generic template. I cannot locate this template and I do not know how to fill in some of the required fields for Nextiva setup. Where can I find my Authentication ID, for instance?
  5. leejor
    10,868
    304
    Some providers do not make use of that. The most basic information is...User name (or number), Password, and the SIP server/port. Other fields could probably be be left blank (unless they provide you with something) or you could try putting in either the user, or password if it still won't register.
  6. yuni
    Jul 25, 2012
  7. t0ken407
    Jan 28, 2013
    I'm currently using the 3CX softphone with Nextiva if anyone is still looking for instructions on how to set it up.
  8. blinton
    Dec 12, 2014
    Any information re: Nextiva would be appreciated.
