Setup incomming fax
Discussion in '3CX Phone System - General' started by sunero, Nov 20, 2008.
  1. sunero
    Jul 7, 2008
    11
    I'm trying to setup incomming fax over my AudioCodes Mediant 1000 (PSTN), but without luck.
    The following is what i'm getting from the log :
    15:42:22.354 MediaServerReporting::RTPReceiver [MS105000] C:67.2: No RTP packets were Received:remoteAddr=192.168.12.71:10012,extAddr=0.0.0.0:0,localAddr=192.168.12.71:7408
    15:42:22.354 Call::Terminate [CM503008]: Call(67): Call is terminated
    15:42:22.308 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for DID:208701 forwards to Fax:888
    15:42:22.308 LineCfg::getInboundTarget [CM503009]: DID rule (208701) is applied to call from sip:0044132xxx6815@sip.apollon.dk:5060 to xx208701
    Do I need to setup anything in my AudioCodes?
    And is there a way to test my 3CX fax internally just by sending a fax job directly to the fax number 888?
