setup Q
Discussion in '3CX Phone System - General' started by mylove4life, Dec 13, 2011.
  1. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    Hi all, do I have to delete my ring groups before I setup any Call Queues?
    10,375
    231
    Are you talking about re-using the same extensions from the ring group in queues?
  3. mylove4life
    Jan 7, 2010
    165
    yes, I have ring groups now and with looking at the doc's I take it I have to delete them and then setup Q's, am I right?
  4. leejor
    10,375
    231
    I'm not sure if it just won't allow you to add ring group members to a queue. I doesn't hurt to try, if it doesn't allow, then you'll simply have to delete them. If that is the case, and the phones support it, you could add the ring group line on a second key.
  5. mylove4life
    Jan 7, 2010
    165
    I think the best thing would be to just delete the ring groups and add a Q for each of the departments. Anyone else like to comment?
  6. mylove4life
    Jan 7, 2010
    165
    That worked like a charm.... delted the ring groups and made Q's for them... took 10 minutes :)
