Setup Siemens Gigaset A580IP
Discussion in '3CX Phone System - General' started by mhnichols, Aug 15, 2011.
  1. mhnichols
    May 22, 2009
    11
    HI, I am trying to setup a Siemens Gigaset A580IP Dect Handset, managed to get it to register to the server, can receive incoming calls OK, but unable to initiate any calls from the handset?
    I just get repetative tones, but nothing seems to happen.
    Does anyone know how to get this working?
    Regards
    mark
  2. willow
    willow Member
    Mar 1, 2011
    471
    you would need to post a log of the phone trying to make a call. was the call external or internal? it may be the dialplan that is setup on the phone. The 3cx doesnt provide feedback tones, it normaly provides a voice prompt about what is going on.
