Solved Setup Transfer out of voicemail
Discussion in '3CX Phone System - General' started by that1guy, Sep 21, 2017.
  1. that1guy
    Jul 27, 2017
    46
    Greetings,
    How do I setup transferring out of voicemail?
    Example: Caller attempting to reach extension A. A is busy, call is routed to voicemail. Caller would like to dial extension B during the outgoing voicemail message, thus being transferred out of voicemail.
    I have been trying to transfer out of my own voicemail message, however I am consistently routed back to my voicemail message.
    Any help will be greatly appreciated.
    10,586
    252
    I believe that a transfer to the operator extension is about it, at this point. If you don't actually make use of the operator, you could forward to a digital receptionist to allow the caller additional choices.
    #2 leejor, Sep 22, 2017
  3. Archie Frederic
    Jan 31, 2017
    72
    edit extension. go to forwarding rules then do as you like.
  4. that1guy
    Jul 27, 2017
    46
    Thanks for the suggestion. I might make use of that. My client's previous phones system allowed this option, and I thought it worked with 3cx. I could very well be mistaken. I'll see what I can do.
  5. that1guy
    Jul 27, 2017
    46
    Thanks for all the suggestions. I ended up utilizing the Operator extension to get things working.
