Setup
Discussion in '3CX Phone System - General' started by chrissnap, Dec 30, 2014.
  1. chrissnap
    Dec 30, 2014
    Quick question.
    My end user is wanting when a caller is transferred to an extension, if no one answers the extension to be able to say hit 0 and get back to the main IVR.
    Possible?
    Thanks,
    Chris
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,313
    249
    I think * or 0 both work... and you need to setup your operator extension under Settings -> General.
    There is not an option for a different operator for an extension or extension group - just global.
  3. chrissnap
    Dec 30, 2014
    Thanks for the reply.
    So, It does not matter whether or not vm has picked up at the point of hitting * or 0?
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    It will only return the call to the operator and not to the IVR. It should do even if the VM has picked up. Give it a try using the "*".
  5. craigreilly
    Feb 1, 2012
    3,313
    249
    Can you set operator ext to an IVR? If not - I guess forward a dummy extension to an IVR.
    Never had the need to do this...
  6. leejor
    10,744
    281
    Yes, I have this working.
