setupconfig.xml - is there any option to apply more settings?
Discussion in '3CX Phone System - General' started by jhn, Jan 30, 2018.
  1. jhn
    Aug 21, 2017
    we are using setupconfig.xml to automatically configure our 3CX installations.
    Everything works fine.
    However, I'd like to check if we are able to push more config (besides the settings which are included in setupconfig.xml sample file provided by 3CX)?
    Just to name few random examples ->
    Extension settings:
    webclient password
    disable voice mail
    hide extension from company phone book
    configure extension with system admin rights
    System config:
    disable sending welcome e-mail for newly created extensions
    customize e-mail templates
    When experimenting with setupconfig.xml file, all custom settings we add are ignored - the file passes validation and 3CX gets configured, but none of our custom settings is applied.
    As an example, adding <VMEnabled>false</VMEnabled> into extension node in xml file doesn't disable voicemail.
    Looking at PbxWebConfigTool.log, our custom setting is being ignored.
