Setupconfig.xml
Discussion in '3CX Phone System - General' started by Marijn Paques, Mar 5, 2018.
Tags:
  1. Marijn Paques
    Feb 23, 2018
    6
    Dear 3CX,
    We have done some testing with the SetupConfig.xml and are trying to streamline our installation procedure by using the SetupConfig.
    We downloaded the SetupConfig.xml file from your website and simplified and modified the file. After changing it we tried to use it on the setup of our test system, but got a server error when loading the file.
    Could you please assist and/or do you have any additional guidelines regarding the SetupConfig?
    With kind regards,
    Marijn Paques
    Accent Automatisering
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    40
  3. Marijn Paques
    Feb 23, 2018
    6
    Dear Marios,
    I have looked in more detail on the webpage and I've found out that when adding all the certificate information and activating the SetupConfig.xml by using the commandline I got it working.
    One thing that I can't seem to get working is the build a PBX with an existing own FQDN I contiueasly get the following message.
    I have release the FQDN from the customer portal, so for my understanding I should be able to get is working.
    Could you help me with this?
    With kinds regards,
    Marijn Paques
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @Marijn Paques
    Please send me a p.m. with the FQDN you are trying to use so we can check.
