shared extension
Discussion in '3CX Phone System - General' started by t4mack, Sep 13, 2010.
  1. t4mack
    Jan 19, 2010
    56
    Anyone know how to configure an extension to be shared. What I want is have two phones with the same extension. when i pick up the phone i want to be able to listen in on the other phone. I need this to work for analog phones that we are going to be using when the power is out. These phones all will have one extension configured so when we put someone on hold the call can be picked up from another phone.
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    For analog phones you need an ATA so how will the ATA work when the power is out?
    If you do get the ATA working (and presumably the 3cx) then the PAP2T does shared extensions. In the configuration you can tell it if is it a shared extn (has a drop down for yes or no) for each line you configure.
  3. t4mack
    Jan 19, 2010
    56
    I currently use a the Grandstream GXW-4008. I works with the power out. i just need to find where i can configure the shared line.
  4. leejor
    11,116
    329
    Why don't you just connect two phones to the same ATA?
  5. t4mack
    Jan 19, 2010
    56
    They are, it just doesn't seem to be working just by plugging it up and configuring it to that extension.
  6. leejor
    11,116
    329
    What is it that's not working?
    Generally, and there may be some ATA's with options that make an exception, when you put the same extension/phone number on to two ATA's they will both receive calls to the number but one won't be able to pick up and listen in when the other is on the phone. The second person will just get dialtone. it sound like you want a single ATA going into a key system, or into phones that have a physical "hold' button on the set, the type that puts resistance across the line until an extension picks up the call.
  7. t4mack
    Jan 19, 2010
    56
    Correct. I thought that there was a setting in 3cx to allow a shared extension to function that way.
