Shared Park disconnects calls -- Can't pickup
Discussion in '3CX Phone System - General' started by ithdwy, May 13, 2011.
  1. ithdwy
    May 13, 2011
    I have a V9 (upgraded from 7) commercial system with AAstra 6753i Phones (on 2.6.0.66 Firmware and one 2.6.0.2010 for testing). I have one programmable key set for BLF/Xfer - SP1 for a shared Park call. On internal calls everything works fine. All external calls park fine but when we try to pickup we get onhold music and the external call disconnects. this happens with 3cx softphone park/pickup as well? We are using a VOIP provider.
    any help would be great.
    Here is a log of a park/pickup attempt
    01:34:03.453 [CM503008]: Call(871): Call is terminated
    01:34:02.938 [CM503008]: Call(870): Call is terminated
    01:33:59.516 [MS105000] C:870.2: No RTP packets were received:remoteAddr=127.0.0.1:40086,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7398
    01:33:57.922 [CM503007]: Call(870): Device joined: sip:xxxxx@xxxxxx:5060
    01:33:57.891 [CM505003]: Provider:[459-0238] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhoneSystem 9.0.15776.0] PBX contact: [sip:xxxxxxxx@xxxxxxxxx:5060]
    01:33:57.891 [CM503002]: Call(870): Alerting sip:xxxxx@xxxxxxx:5060
    01:33:57.688 [CM503007]: Call(871): Device joined: sip:xxxxx@xxxxx:5060
    01:33:57.407 [CM505003]: Provider:[459-0238] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhoneSystem 9.0.15776.0] PBX contact: [sip:xxxxxx@xxxxxxxxx:5060]
    01:33:57.391 [CM503008]: Call(869): Call is terminated
    01:33:57.328 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10005 forwards to DN:8002
    01:33:56.907 [CM503025]: Call(870): Calling @[Dev:sip:xxxxx@xxxxxxx:5060]
    01:33:56.641 [CM503007]: Call(870): Device joined: sip:SP1@127.0.0.1:40000;rinstance=17bbfd0f561e03a9
    01:33:56.641 [CM503007]: Call(870): Device joined: sip:1009@192.168.1.23:5060;transport=udp
    01:33:56.578 [CM505001]: Ext.SP1: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Parking orbit;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Parking Orbit] PBX contact: [sip:SP1@127.0.0.1:5060]
    01:33:56.578 [CM503002]: Call(870): Alerting sip:SP1@127.0.0.1:40000;rinstance=17bbfd0f561e03a9
    01:33:56.422 [CM503025]: Call(870): Calling Ext:Ext.SP1@[Dev:sip:SP1@127.0.0.1:40000;rinstance=17bbfd0f561e03a9]
    01:33:56.375 [CM503004]: Call(870): Route 1: Ext:Ext.SP1@[Dev:sip:SP1@127.0.0.1:40000;rinstance=17bbfd0f561e03a9]
    01:33:56.375 [CM503010]: Making route(s) to "SP1"<sip:SP1@192.168.1.11:5060>
    01:33:56.360 [CM505001]: Ext.1009: Device info: Device Identified: [Man: Aastra;Mod: 5x series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [Aastra 53i/2.6.0.2010] PBX contact: [sip:1009@192.168.1.11:5060]
    01:33:56.344 [CM503001]: Call(870): Incoming call from Ext.1009 to "SP1"<sip:SP1@192.168.1.11:5060>
    01:33:49.547 [CM503007]: Call(869): Device joined: sip:SP1@127.0.0.1:40000;rinstance=17bbfd0f561e03a9
    01:33:49.500 [CM505001]: Ext.SP1: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Parking orbit;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Parking Orbit] PBX contact: [sip:SP1@127.0.0.1:5060]
    01:33:49.500 [CM503002]: Call(869): Alerting sip:SP1@127.0.0.1:40000;rinstance=17bbfd0f561e03a9
    01:33:49.313 [CM503025]: Call(869): Calling Ext:Ext.SP1@[Dev:sip:SP1@127.0.0.1:40000;rinstance=17bbfd0f561e03a9]
    01:33:49.250 [CM503004]: Call(869): Route 1: Ext:Ext.SP1@[Dev:sip:SP1@127.0.0.1:40000;rinstance=17bbfd0f561e03a9]
    01:33:49.250 [CM503010]: Making route(s) to "SP1"<sip:SP1@192.168.1.11:5060>
    01:33:49.235 [CM505003]: Provider:[459-0238] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhoneSystem 9.0.15776.0] PBX contact: [sip:xxxxxxxx@xxxxxxxxxx:5060]
    01:33:45.453 [CM503003]: Call(869): Call to sip:1007@192.168.1.11:5060 has failed; Cause: 487 Request Terminated; from IP:192.168.1.22:5060
    01:33:44.422 [CM503003]: Call(869): Call to sip:1008@192.168.1.11:5060 has failed; Cause: 487 Request Terminated; from IP:192.168.1.34:5060
    01:33:44.391 [CM503003]: Call(869): Call to sip:1001@192.168.1.11:5060 has failed; Cause: 487 Request Terminated; from IP:192.168.1.20:5060
    01:33:44.328 [CM503003]: Call(869): Call to sip:1005@192.168.1.11:5060 has failed; Cause: 487 Request Terminated; from IP:192.168.1.105:5060
    01:33:44.282 [CM503003]: Call(869): Call to sip:1006@192.168.1.11:5060 has failed; Cause: 487 Request Terminated; from IP:192.168.1.25:5060
    01:33:44.203 [CM503003]: Call(869): Call to sip:1010@192.168.1.11:5060 has failed; Cause: 487 Request Terminated; from IP:192.168.1.29:53371
    01:33:44.172 [CM503003]: Call(869): Call to sip:1005@192.168.1.11:5060 has failed; Cause: 487 Request Terminated; from IP:192.168.1.28:53283
    01:33:43.985 [CM503007]: Call(869): Device joined: sip:1009@192.168.1.23:5060;transport=udp
    01:33:43.969 [CM503007]: Call(869): Device joined: sip:xxxxx@xxxxx:5060
    01:33:41.125 [CM505001]: Ext.1007: Device info: Device Identified: [Man: Aastra;Mod: 5x series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [Aastra 53i/2.6.0.66] PBX contact: [sip:1007@192.168.1.11:5060]
    01:33:41.125 [CM503002]: Call(869): Alerting sip:1007@192.168.1.22:5060;transport=udp
    01:33:41.063 [CM505001]: Ext.1001: Device info: Device Identified: [Man: Aastra;Mod: 5x series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [Aastra 53i/2.6.0.66] PBX contact: [sip:1001@192.168.1.11:5060]
    01:33:41.063 [CM503002]: Call(869): Alerting sip:1001@192.168.1.20:5060;transport=udp
    01:33:41.016 [CM505001]: Ext.1005: Device info: Device Identified: [Man: Aastra;Mod: 5x series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [Aastra 53i/2.6.0.66] PBX contact: [sip:1005@192.168.1.11:5060]
    01:33:41.000 [CM503002]: Call(869): Alerting sip:1005@192.168.1.105:5060;transport=udp
    01:33:40.969 [CM505001]: Ext.1009: Device info: Device Identified: [Man: Aastra;Mod: 5x series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [Aastra 53i/2.6.0.2010] PBX contact: [sip:1009@192.168.1.11:5060]
    01:33:40.969 [CM503002]: Call(869): Alerting sip:1009@192.168.1.23:5060;transport=udp
    01:33:40.922 [CM505001]: Ext.1006: Device info: Device Identified: [Man: Aastra;Mod: 5x series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [Aastra 53i/2.6.0.66] PBX contact: [sip:1006@192.168.1.11:5060]
    01:33:40.922 [CM503002]: Call(869): Alerting sip:1006@192.168.1.25:5060;transport=udp
    01:33:40.875 [CM505001]: Ext.1008: Device info: Device Identified: [Man: Aastra;Mod: 5x series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [Aastra 53i/2.5.1.41] PBX contact: [sip:1008@192.168.1.11:5060]
    01:33:40.875 [CM503002]: Call(869): Alerting sip:1008@192.168.1.34:5060;transport=udp
    01:33:40.844 [CM505001]: Ext.1010: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 5.0.14900.0] PBX contact: [sip:1010@192.168.1.11:5060]
    01:33:40.844 [CM503002]: Call(869): Alerting sip:1010@192.168.1.29:53371;rinstance=e195a4eb090d4ab5
    01:33:40.719 [CM505001]: Ext.1005: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 5.0.14900.0] PBX contact: [sip:1005@192.168.1.11:5060]
    01:33:40.719 [CM503002]: Call(869): Alerting sip:1005@192.168.1.28:53283;rinstance=33d05788139149e3
    01:33:40.594 [CM503025]: Call(869): Calling RingAll8002:1001Ext.10011005Ext.10051006Ext.10061007Ext.10071008Ext.10081009Ext.10091010Ext.1010@[Dev:sip:1010@192.168.1.29:53371;rinstance=e195a4eb090d4ab5]
    01:33:40.563 [CM503025]: Call(869): Calling RingAll8002:1001Ext.10011005Ext.10051006Ext.10061007Ext.10071008Ext.10081009Ext.10091010Ext.1010@[Dev:sip:1009@192.168.1.23:5060;transport=udp]
    01:33:40.532 [CM503025]: Call(869): Calling RingAll8002:1001Ext.10011005Ext.10051006Ext.10061007Ext.10071008Ext.10081009Ext.10091010Ext.1010@[Dev:sip:1008@192.168.1.34:5060;transport=udp]
    01:33:40.516 [CM503025]: Call(869): Calling RingAll8002:1001Ext.10011005Ext.10051006Ext.10061007Ext.10071008Ext.10081009Ext.10091010Ext.1010@[Dev:sip:1007@192.168.1.22:5060;transport=udp]
    01:33:40.500 [CM503025]: Call(869): Calling RingAll8002:1001Ext.10011005Ext.10051006Ext.10061007Ext.10071008Ext.10081009Ext.10091010Ext.1010@[Dev:sip:1006@192.168.1.25:5060;transport=udp]
    01:33:40.469 [CM503025]: Call(869): Calling RingAll8002:1001Ext.10011005Ext.10051006Ext.10061007Ext.10071008Ext.10081009Ext.10091010Ext.1010@[Dev:sip:1005@192.168.1.105:5060;transport=udp]
    01:33:40.453 [CM503025]: Call(869): Calling RingAll8002:1001Ext.10011005Ext.10051006Ext.10061007Ext.10071008Ext.10081009Ext.10091010Ext.1010@[Dev:sip:1005@192.168.1.28:53283;rinstance=33d05788139149e3]
    01:33:40.438 [CM503025]: Call(869): Calling RingAll8002:1001Ext.10011005Ext.10051006Ext.10061007Ext.10071008Ext.10081009Ext.10091010Ext.1010@[Dev:sip:1001@192.168.1.20:5060;transport=udp]
    01:33:40.360 [CM503004]: Call(869): Route 1: RingAll8002:1001Ext.10011005Ext.10051006Ext.10061007Ext.10071008Ext.10081009Ext.10091010Ext.1010@[Dev:sip:1001@192.168.1.20:5060;transport=udp,Dev:sip:1005@192.168.1.28:53283;rinstance=33d05788139149e3,Dev:sip:1005@192.168.1.105:5060;transport=udp,Dev:sip:1006@192.168.1.25:5060;transport=udp,Dev:sip:1007@192.168.1.22:5060;transport=udp,Dev:sip:1008@192.168.1.34:5060;transport=udp,Dev:sip:1009@192.168.1.23:5060;transport=udp,Dev:sip:1010@192.168.1.29:53371;rinstance=e195a4eb090d4ab5]
    01:33:40.344 [CM503010]: Making route(s) to <sip:8002@192.168.1.11:5060>
    01:33:40.328 [CM505003]: Provider:[459-0238] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhoneSystem 9.0.15776.0] PBX contact: [sip:xxxxxxx@xxxxxxx:5060]
    01:33:40.313 [CM503001]: Call(869): Incoming call from +130XXXXXXXX@(Ln.10005@459-0238) to <sip:8002@192.168.1.11:5060>
    01:33:40.313 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10005 forwards to DN:8002
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Default settings of Voip provider connection:
    You need to remove tick from "supports re-invite" in voip provider configuration.
  3. ithdwy
    May 13, 2011
    Thanks,
    Re-invite was not checked but replace was, removed the tick and all is well.
