Shared Park forwarding extensions no longer possible?
Discussion in '3CX Phone System - General' started by jbryant84, Jan 31, 2017.
  1. jbryant84
    jbryant84 New Member
    Apr 6, 2016
    107
    39
    When migrating some clients from other PBXs they're used to 501-509 for shared park calls so we try to keep that in place. In V14 we set SP1 as the mobile number. For v15 we've used the 'If my phone is busy/unregistered forward calls to:' dialog. Has this functionality been removed? The fully up to date v15 install I'm currently working on gives an error message I've never seen before "Invalid outside number". Is anyone aware of another workaround?
  2. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
  3. curtcar21
    Jul 7, 2016
    33
    5
    Ok I know its not the best way, but if you tap to the left or the right of the 3cx logo you will get a keyboard type SP0,SP1 etc to pick up call(like v14). We are running the very latest version of V15 as of 2-10-17. A button would be nice but at least this helps. Hope it helps others
