Shared park in Version 11
Discussion in '3CX Phone System - General' started by khostet, Jul 25, 2012.
  1. khostet
    Mar 10, 2010
    I have upgraded to version 11 and have Grandstream 2100 phones with frimware 1.0.4.9.
    In ver 10 the phones had to blfs as SPO and SP1. Calls could be parked by answering call hot transfer then a park button.
    Now when you hit the transfer button a message appears on screen to dial ext or select button. The call will not park when the button is select, it can be transfered by dialing an ext. I have given the users the rights to park and un park calls.
    What am I missing to use this function?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    How were the phones originally provisioned? Is it possible that it was done manually and now with V11 they were over written by a new default template? Use the phones web browser interface and see how the phone is truly programmed and then compare to how 3cx thinks it is.
  3. khostet
    Mar 10, 2010
    The phones were provisioned with 3cx, attached image of blf config in phone.
  4. lneblett
    Sep 7, 2010
    2,086
    64
    Hmmm. I ran into something similar on an older firmware Polycom. Had to hit transfer, then blf associated to sp, and then transfer again. Unfortunately, I do not have a Grandstream around to help. If I visit a customer site in the next day or two, I will see what I find.
  5. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    Try to factory reset the phones and auto-provision them again. We tested with GXP 2100 v.1.0.4.9 and it's working like this.
    1. Answer incoming call
    2. Press Transfer - message "Dial number OR select line" is displayed
    3. Press BLF key defined to monitor a SP and call is transferred to a shared parking locations.
    4. Press again that BLF key to pickup the call
