Shared Park on Iphone
Discussion in 'iOS' started by danturk, May 3, 2012.
  1. danturk
    Oct 21, 2011
    Is there a way to get to the shared Park orbit from the Iphone App? How can I Dial SP0 from the Iphone?
    Device Info
    Phone Model: [iPhone]
    Generation: [4]
    Firmware Version: [4.2.1]
    Jailbreak: [NO]
    Cydia Installed: [??]
    Issue Info
    Handset: [Phone]
    Contacts: [Local]
    Connection: [WiFi|3G]
    Server: [External]
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    Non-numeric characters may be typed by using iPhone's keyboard; tap 3CXPhone's display and it will be shown (assuming you're using 3CXPhone 1.1.5)
