Shared Parking and Yealink W52P
Discussion in '3CX Phone System - General' started by vondie, Oct 21, 2013.
  1. vondie
    Oct 16, 2013
    16
    We are trying to use the Yealink wireless handset W52P to be able to access the shared parking system extension SP0 with our v11 system. We have Yealink T3x phones successfully programmed using a DSS key for SP0 which works great. So far, we have not found a way with the wireless handset to at least access SP0. We have tried creating an SP phonebook and then tie a contact (which the phone number is SP0), but the handset translates the number to 3P0 and fails to connect. Anyone run into this and found a solution?
    Thanks,
    Tim
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,569
    302
    So I just tried this in v11:
    New Extension, enter the Mobile Numebr as SP0.
    Set phone to always goto Mobile.
    So, dial this "extension" and 3cx will transfer to SP0.
    I have not tested it v12.
  3. vondie
    Oct 16, 2013
    16
    Brilliant! You made my week!
    I tried to forward, but never thought to use the mobile number.
